Prefersdirt
- Sep 28, 2019
- 377
Then you would have a guy like me out there trying to play with the deuce!Rubber 50 cal on opposing corners of the sea container?
You can get wire through nuts - you wire the nut onto the bolt when you are done. You can spot-weld a few nuts/bolts if that is easier. Seems like a TON of work. Blue loctite would still let you get things apart if you need to but make it harder to take apart. Red will do that too - just make your life a nightmare if you have to take it apart (been there/done that).
