rodrick
Free energy enthusiast
Looking at the voltage for a Canadian solar 400 watt panel the voc is 47.2 on the one I foundPurchased EG4 6000XP, (split phase), (10) new 400W Canadian Solar panels and an EG4 100amp battery. LL-S. 6000XP takes 480v max, 4000 watts per mppt. Panels are 37.1 amps each, living in Missouri. So far, I have mounted my panels to the roof, and hung my inverter next to my main panel. Just getting started, and enjoying the learning process. I will proceed with cation.
If you run 10 in series your voltage will be 472 volt without temperature adjustment this is to high you will destroy your inverter, you need to find lowest temperatures for your area then set your panels up according to voc and temperature adjustment
Doing some quick calculations I would suggest 8s max
you can exceed watts but voltage is a hard limit
