Georgia DIY Solar
- May 21, 2020
- 1
Looking for brackets to use for attaching standard rigid 100 watt panels. The peaks in the panels are not vertical enough to use the clamp type I see in you tube. I assume I would need a clamp that installs on the peak, with self tapping screws. Also to protect the solar panel wires, I need to run conduit thru the roof and a metal under ceiling a foot or so under the roofing. This is a roof over a open air deck, not over living area.
Thanks
Bruce
![IMG_20200521_164711350_HDR.jpg IMG_20200521_164711350_HDR.jpg](https://diysolarforum.com/data/attachments/13/13657-3170556d85977b5c283f1f1c58e17905.jpg)
Thanks
Bruce
