So, some people on a DLIVE chat say producing solar equipment produces a lot of pollution. Also, after an EMP batteries won't work some are saying. Also charge controllers will be shot. Any feedback? (I have a Faraday bag, but hard to get in a battery and can't use the battery if its in the bag.)
Anything man made will create pollution, so simply don't take your hardware as 'Disposable' or for granted...
The longer it's used, the more it offsets it's initial production pollution.
While the political/big energy argument has blown the pollution produced WAY out of proportion, for instance claiming the aluminum in the frames creates 10,000 times the pollution any other aluminum production does,
The silicone in solar panels creates 100,000 times, or more, pollution than the silicone for smart phones, etc.
Everything has its costs, no need to exaggerate the problem...
The 'Simple' truth is,
After the cost/pollution of creating the solar panels, there is no pollution in the service life.
While fossil fuel will turn 60% to 80% of those fossil fuels into NOTHING BUT pollution,
Burning fossil fuels is between 20% & 40% efficient, that's 80%-60% waste heat/pollution, and you can't change the laws of thermodynamics, it's always going to be that way.
Solar creates ZERO pollution during it's working life.
Once someone does large scale electro-chemical process for removing heavy metals from panels at the end of their lives, this *Can* be a closed cycle.
Right now it's not economically viable, so no one is doing it large scale.
*IF* a CME (nature) decides to throw a fit, you will be good.
What gets through the magnetosphere won't effect your panels or electronics.
*IF* someone can pull together the multi-billion dollar (minimum) specialized nuclear device for an EMP,
Can get a lift vehicle to get that device into place inside the high atmosphere,
Have a guidence system to precisely locate that lift vehicle & nuclear device,
Can build a specialized launch platform for that lift vehicle,
And can track the ever moving magnetic field for the optimum place to park that EMP device,
Then you have to worry about something you can't do anything about.
Spare parts fixes anything an EMP can do...
Solar Panels, likely not effected by EMP, will charge batteries directly, YOU will have to monitor charging but they will still make DC current, and your batteries will still accept DC current.
Stick a cheap multi-meter in your bag.
