Hello,
We have a grid tied 13.8 Kw system with an SE10000H inverter which states it's maximum output is 10,000 watts. We had a company design the system and I installed. I just realized that the inverter will not realize the maximum potential of the solar array (not sure what the designer was thinking). We have 3 strings on the array each with 4,620 watts. I'm going to install a 5,000 watt second inverter and move one string to the second inverter. My question is can I connect the AC lines from the two inverters together prior to going into the DC disconnect. I would connect them with an insulated terminal block. I tried contacting Solaredge Tech support and that is beyond worthless.
Thanks for any advise!
