DaveF
[UPDATE] May 30, 2023 They finally responded with a password. I'll refresh my other questions and see how it goes.
I recently purchased three, 24V 200Ah batteries from Solarpowerstore.ca Solar Lithium Battery Server Rack - LiFePO4 24V 200Ah 5120Wh Smart BMS
and have had no response to my technical inquires since.
The batteries themselves seem just fine: separate power switch + breaker with pre-charge startup. Tested to rated capacity.
They arrive with 2AWG 18" cables with the specialized plug-type connectors needed for the battery, but you'll have to snip and re-lug them to connect to a standard bus-bar.
The manual is minimal, and although it says it can connect to a wide variety of inverters, the BMS parameters can't be set from the front panel, there's no way to set the communication protocol, and unlike other locked down batteries the order page does not offer to set the protocol before shipping (and since I didn't know it was locked down, I didn't ask).
I couldn't see what brand BMS it uses without taking the battery apart further than I was comfortable with, and they won't say what it is.
They did provide the BMS monitoring software BEFORE the purchase, but it requires a password that, so far, they haven't provided.
