I have 3 48v 100ah batteries from SolarPowerStore.ca that i'm done with, now that I finished building my shelf of DIY storage.
They are less than a year old, have maybe 50ish cycles (probably less) on them and work great.
I got them with a rack that has room for 6 in total, and has built in busbars.
Asking $2100 CAD each, if you buy all 3 then I will throw the rack in free. ($6300 all-in)
They are $2400 new, and the rack is $770. After 13% tax that would be just over $9000.
Located in south central New Brunswick.
Batteries:
Rack:
Pics:
Batteries:
Solar Lithium Battery Server Rack - LiFePO4 48V 100Ah (51.2V nominal) 5120Wh Smart BMS Rechargeable Lithium Iron Phosphate Battery
DATASHEET MANUAL MSDS REPORT CE REPORT UL Report (For Cells) - Hidden On/Off key (RST key, press and hold >3s) - Create 48 Volt Storage Systems - Connect in parallel, up to 16 for 81,920 Watts - Automatic system cell balancing - All parameters available on the LCD display - Temperature...
solarpowerstore.ca
Rack:
Rack for server battery Fits 24V & 48V 5Kw Models
Please note that the although the 2,3 and 4 cabinet are currently stuck at the port at BC due to shortages in rail carts. This server Rack is designed to perfectly fit: 2,3, or 6 of our 24V or 48V server rack batteries. It is the perfect solution to stack multiple batteries in parallel to help...
solarpowerstore.ca
Pics:
Dropbox - File Deleted - Simplify your life
www.dropbox.com
