You say 8%, but the graph shows about 14% minimum before the solis charges from grid again?
Something is clearly not right - I don't have the solis cloud app, so unfamiliar with the format of your setting. What I don't follow is whey the meter current is 15.82A (which corresponds with active power of 3568W), but 'battery power' is only showing 15W and IIRC, you don't have PV input.
But, the puzzling one to me, and maybe, just maybe, is confusing the inverter is the OverCharge SOC is set to 0%. That should be set to 100%, or whatever maximum you charge to.
So, first I'd set the OverCharge SOC to 100%, reboot the inverter and see what happens.
Then, if that doesn't resolve the issue, I'd try changing some of the other SOC % settings to see if any have an effect on the inverter's behaviour.
