Traffman
I have 2 sp6548 Inverters with 2 sg48100P batteries. I am running split phase with BMS communications plugged into the SP1 inverter. Sungold said to set SP1 to PYL and SP2 to User Defined. The SP1 gives me an 04 low battery warning but SP2 shows no warning indication. I am currently charging Both utility and MPPT. When just charging with MPPT for some reason the batteries lost charge even though the inverters show charging. I do have 3ea. 450watt panels on each inverter. My question is :
1. Why do I get the low battery alarm on SP1 only and
2. Why do I lose battery power with both inverters charging on MPPT only.
