l00semarble
- Jan 1, 2022
- 151
I am working on a design for a system of about 25kw to power my off-grid house with consumption of about 30kwh/day.
My PV arrays will be on a ground mount some distance from the house (maybe 300m). In order to transmit power most efficiently over this distance I was going to run the PV cabling off the arrays at high DC voltage to the house. I was thinking that with the Victron MPPT RS 450/200 I could transmit power at over 400v which would require smaller cables etc.
For those that don't know the Victron nomenclature for their MPPTs is XXX/YYY which is (Max PV input VOC)/(Max output current) so a 450/200 can take up to 450v pV input and can make up to 200 amps output to batteries. The RS 450/200 can do 11,520w and I was going to overpanel them a bit.
But now looking more closely at specifics on this arrangement I see that the RS 450/200 has 4 separate MPPT trackers and each needs to be wired separately with its own array so I will need 4 separate arrays into each Controller. Each array can be 450VOC and up to 18a (before allowed overpaneling.) 450v*18a = 8,100w but the total output can't be over 11,520w so no reason to put 8,100w on each of the 4 trackers.
So I was playing with some numbers to max out two of these controllers with large format panels for example the Trina Vertex bifacial 500w which is:
51.5VOC, 43.4MPP V, 12.13A short circ I, 11.53A MPP I.
So to "fill up" a RS 450/200 I can only do 6 panels per array which gives me each array with:
309 VOC, 260.4v MPP, 3,000w, 11.53A MPP I and 4 strings like this is 12,000w which is a nice little 4% overpaneled. All good, right? I can "Max Out" 2x MPPT RS 450/200 and get about 23,000w output....
but...
the working voltage of the panels to the MPPT in this config is only 260v. I really was hoping to do the long distance transmission at over 400v. 260v is not much better than just putting the inverters at the ground rack and transmitting 240v AC. And....I was imagining using two high voltage DC conductors for each MPPT but in reality I will need 8 conductors per MPPT or 16 conductors total.
So I am realizing that the 'huge' 450v/200a MPPT controller is really 4 separate 450v/50a controllers and it isn't easy to make a string to max the voltage.
I need PV panels with higher VOC and lower current but they don't seem to go much above 50VOC. Sorry....post got long. Probably hard to read and follow but if anybody cares to it is the folks here. Thoughts?
but...
