chrisski
Solar Boondocker
- Aug 14, 2020
- 5,398
I made thicker leads for my Bench Top Power supply, and this made a huge difference while charging the batteries.
Went from 3.6 amps in Constant Voltage with the tiny terminals that came with the power supply to 10 amps in constant current mode for the 10 AWG wires. This should cut down charge time significantly.
This is the Power Suppy I got, I think its the same one Will Recommends:
To make the new cables, I simply used 12 inches of 10 AWG Wire with an auto parts store 1/4" ring terminal crimped on each end of the wire.
