I am building a three phase power supply with three Conversol single phase inverters, and a Pylontech US5000 Lithum battery at 48 volts. Can I charge the battery from a single phase supply, (230v 50Hz UK spec), connected to the AC input of just one inverter ?
The three phase option is working fine and has been tested.
If I apply grid power to L1 it will bypass the inverter and connect the output directly to the grid source.
My concern is that having set up the three inverters as a three phase unit there may be a problem if one phase is connected to the grid while the other two are still reliant on the battery.
