Zwy
Emperor Of Solar
Your are limited to charging under 30V with the power supply. So you have to use 8S to charge using the 30V power supply.So the BMS's 0.6 amp balancing isn't to low to depend on?
Also you say ~28Volts but 16s would be for 48V system?
Yes, the 0.6A will work but you have to set overall pack voltage low enough plus limit amps as you approach higher cell voltages. That is why you move up in steps. 28V would be 3.5V per cell and balance should begin at 3.4V. Once you see any cells over 3.4V, then turn the amps down lower. This gives the passive balancer time.
