I assume your 450/200 fans turned on at some point, on my 450/100 it seems to turn on one fan at around 1000W, 2nd fan around 1500-2000W. Not objectionable at all.Size comparison to the 120amp growatts.
They ran most of the day; it stayed between 5400 and the highest, 6051w. I could not hear it all over the growatts running.I assume your 450/200 fans turned on at some point, on my 450/100 it seems to turn on one fan at around 1000W, 2nd fan around 1500-2000W. Not objectionable at all.
I discussed wrapping those in a previous post since the two-hole adapters put them closer together than the older style. Here's the delta between the old and new, showing their differences. I will work on addressing that today.Tie bars of different voltage close together, and flat conductor could bridge.
Have any particular protection? Probably a plastic lid?
How about a rectangular plastic strip down the middle, standing taller than the busbars?
I'm unsure; I wanted 30 panels on each one. The math is 48.7 * 10.14 * 15 = 7407.27, which I would divide between two inputs.Three your final count for the 450/200s?
Ok so you are under panelling a fair bit then.I'm unsure; I wanted 30 panels on each one. The math is 48.7 * 10.14 * 15 = 7407.27, which I would divide between two inputs.
That would be 30.51 amps, with the two inputs having 36 amps on the victron.
