carlos33071
Good morning l, so this is my first time posting. I have a victron inverter 12/3000 that keeps popping the breaker when on. short power. I have a 30 amp breaker, everything works fine until I hook up to short power a 20 amp outlet gfci or another at the water plant where I work, with no load breaker on the off position after the inverter. Even when I disconnect the 120 out, meaning I pull the wires out or I removed the a/c in and just connect a short power line to it a outlet. It happens after 2 seconds when the short power is on, I can hear a current noise on the 30 amp breaker that comes from the batteries to the inverter I guess is when is trying to charge the batteries from short power it dosent like it and it trips the breaker. I even try changing the breaker but with the same outcome. I have 2 enduro power 12/200 in a 12 volt system thank you for the help
