Brett V
Mad Scientist
Pricing is better than I expected!
How's the noise level with the new 5kVAs? Silent?Forgot all about those differences.
I'll tell you at 34W of idle capacity (between 2, 5kVAs and a cerbo running) I'm saving approx 3.4kWh a day compared to my 6500s. The larger wiring space was so much nicer to work in as well! No more bloody knuckles!
To you guys running dual 5ks. Are you on or off grid? What is your daily energy consumption and peak load demand?
So much quieter than the ROAR of the jet engines inside the 6500s. These fans seem to be temp controlled and only really kick on once you get above 2800W. In a silent room, they may seem loud, but nothing compared to the constant idle fans on the 6500s. When the fans are off, you hear a low hum of the transformer.How's the noise level with the new 5kVAs? Silent?
At the moment I'm off-grid. Still have to get the AC IN wired up.To you guys running dual 5ks. Are you on or off grid? What is your daily energy consumption and peak load demand?
Not exactly sure. There wasn’t much data when we bought our house and the county doesn’t have anything either. We went to the township years ago to try and get more info and they told us “we show it was built in 54 and has had a lot of additions…”.@Adam De Lay what size is your well pump and how deep is your well? Are you/your family prudent in exercising what can be powered on together or has that been a non issue for you thus far? Thanks for sharing your data!
@sunshine_eggo thx for sharing yours as well!
The Victrons do have a great reputation for extended surge performance.Not exactly sure. There wasn’t much data when we bought our house and the county doesn’t have anything either. We went to the township years ago to try and get more info and they told us “we show it was built in 54 and has had a lot of additions…”.
I know when I ran tests before, it was pulling around 2.4kw. I’ve had some people tell me I have a 1/4 horse, I’ve had others tell me I have 3/4 horse pump.
As far as “exercising” goes, no were all pretty “fit” people…. ?
So far we haven’t focused at all on what’s running and when it’s running. We’re not frugal with using our power. Now things might end up changing after I run some load tests.
Which is why we ditched a Renogy 2000W inverter for a Victron 1000W (1200W for resistive loads like lightweight space heaters). 24W idle for the Renogy, 9W for the Victron and 2W if you use the Eco mode. We’re using the Eco mode powering our 7.4cf fridge. Energy cost was 576 Wh on the Renogy but only 48 Wh on the Victron eco mode. And if we need a short run of a high draw item (I think it’s about 60 seconds), we can power it with the Victron. Ran our full size Dyson vacuum at 1850W for about a minute before the Victron started beeping. Didn’t push it to see for how long it would run before shutting down. Not sure what the startup surge was but it’s gotta be more than the rated 2400W surge the Victron is rated for. Count me impressed.Yeah I just watched that. Ridiculously low idle consumption numbers. Can’t wait to see more on this. Really cool.
That would solve all my issues with wanting more power…. But I’m too committed now to what I already have… drat…!If only it was UL1741...
This is what I would have bought in 2019 if they offered 48V/5kVA MP.
Those numbers are EXTREMELY suspect UNLESS you're just referring to the inverter consumption only as "energy cost" for a 7.4cf fridge should be about 500Wh/day.
Generally, an ECO mode is worthless if any power whatsoever is needed. Generally, the thermostat needs AC power to determine when to cycle the compressor on and off. I'm impressed it's actually working. The reduced frequency signal must be enough to keep the thermostat going.
I don’t yet know enough about how or why it works.
I did have to mess with the settings to get it to work. The default setting only provides power for less than 0.5 seconds, which wouldnt work. I have it set to seek every 15 seconds and provide power for 5 seconds. It also works at powering for only 2.5 seconds, but since I’m not there to change the settings, I wanted to be sure my wife wouldn’t have problems.
Much wisdom!
Yeah I'd consider that a pretty advanced task for a non technical wife.I have created new profiles for both the Victron charger and inverter and have emailed them to her. All she has to do is install them via the Victron Connect app. But she doesn't want to do that, lol. Her eyes gloss over when I start trying to explain these things (in what I think are as simple of terms as possible, but I guess not simple enough, lol.) I guess it can wait until I can be there soon to fine tune it.
