When hooking up Multi+ last year I sometimes used a sorta new and nice heat gun to test outlets and things..I have used it for years to test gen sets and other sources when I wanted to put a good draw on things .
On MEDIUM setting the multi+ dint like the heat gun …and made a loud weird buzzing ( not good ) sound..
On HIGH the multi+ was happy and the heat gun did its thing normally.
I stopped using the heat gun on the Victron…..and haven’t used the gun till today…
A year later ( today) ..
Got out the Honda (very low hours and 2 years old) to fill up for the season..cranked it up for a couple of min and the plugged the heat gun in to it .
The Honda has a voltage output meter on it and it was like normal , about 125 without load..
When I turned on the heat gun to Medium the voltage reading didn’t DROP a little bit like normal , it went UP..
Up to 139 ish ..
I quickly shifted over to HIGH heat and it went down to 123..like normal…
Did it twice to verify #s then unplugged THE GUN from the Honda… the only other info is theres a small amount of a burning plastic smell around the heat gun.
I have now thrown a really nice heat gun in the trash…
The Honda is sitting outside running perfect with a small space heater of about the power of the heat gun on medium…
How is it possible to raise the voltage like that ….?
Why not do it on high…as well on medium…?
Both the Victron and the Honda were affected in strange ways…but work perfect if ya don’t use” that “ heat gun…
Thats why its now in the trash can…
what the hell happened here…Any ideas….?..
J.
Up to 139 ish ..
J.
