RogerD New Member Joined Sep 26, 2019 Messages 109 May 5, 2021 #1 Four 410w panels with 51.2 VOC If all four are wired in parallel the total VOC remains 51.2 - Yes? I ask as Victron 100/50 (24v) controller is 100 VOC max. So the above will work - Yes?
Boondock Saint Solar Enthusiast Joined Apr 8, 2021 Messages 661 May 5, 2021 #2 Are you looking at the Trina panels? I might have to put 2 patallel in my config.
B Bud Martin Solar Wizard Joined Aug 27, 2020 Messages 4,844 May 5, 2021 #3 RogerD said: Four 410w panels with 51.2 VOC If all four are wired in parallel the total VOC remains 51.2 - Yes? I ask as Victron 100/50 (24v) controller is 100 VOC max. So the above will work - Yes? Click to expand... Yes, and the total current will be the sum of 4 panels. In series connection, the total Voltage will be the sum of the 4 panel and the total current will be the current rating of of 1 panel.
RogerD New Member Joined Sep 26, 2019 Messages 109 May 5, 2021 #4 Boondock Saint said: Are you looking at the Trina panels? I might have to put 2 patallel in my config. Click to expand... Yes
Boondock Saint Solar Enthusiast Joined Apr 8, 2021 Messages 661 May 5, 2021 #5 Great, maybe let's compare prices etc in PM. These seem to be the largest I can fit on my RV.
T time2roll Solar Wizard Joined Mar 20, 2021 Messages 5,849 Location SoCal May 5, 2021 #6 Yes the plan for parallel will work fine. Voltage stays the same in parallel.
