Voltronic Axpert VMIII 6kW
john1819
England
Hi,
Im fighting to setup up inverter.
On SBU mode inverter using idle power 100W from battery, its okey but at night when battery running low inverter throwing error 51 because battery at morning are flat even if i set dc low voltage cutoff at 48V
On SUB mode inverter use idle power 100W from utility even if i have solar power to produce it.
Why it is so complicated, is there any workaround for this? Change firmware or something?
I dont wanna buy big battery only for supply inverter idle power :p
Is there option to change from where inverter use idle power?
On SBU should take idle power until dc cutoff voltage
On SUB should take from solar or battery
Because i dont have big battery bank can i connect 48V power supply to battery bank to provide at night idle power?
Power supply will explode? :p
