Ok so here is the problem my off grid system at times may have weeks of snow and no sun at some point. This year after 2 weeks of clouds and snow my batteries are now drained to nothing. Obviously this is not a good thing not to mention I have solar panels attached to 4 Charge controllers that are turned off because batteries are to low. My system is remote and I cant get there to clean panels and check on things often enough.
So my answer is to have at some point when the batteries reach a certain voltage to shut everything down. The problem with this is once the SCC is shut down the batteries will never be able to charge. How do I get the SCC to turn itself on and start charging the batteries on its own, so when the sun comes out things can start working again I would like this to be automatic so once I get there my batteries are charged and also to run my router and my security cameras.
I was thinking that if I took a spur line off of the PV array and added a voltage divider circuit that would never go over say 22 volts that I could charge my batteries without the SCC enough to get the SCC to turn on again and take over. I think I would need blocking Diodes to stop the panels from discharging the batteries while there is no sun. But if the voltage from panels never goes above 22 volts which would be plenty for SCC and not higher than the batteries limits what would be the real danger? I would use some sort of relay that would turn the SCC on once the battery reaches 20 volts or whatever. Could I leave the 20 Volt panel attached? or would I need to have it disconnect once the SCC turns on?
Thoughts please thank you.
