Warpverter
DC current draw is rectified AC current draw (less some smoothing by capacitors).
What waveform do you see in your application?
Yes, the switching bridges draw current in half sinusoids from the bank of big electrolytics.
Current from the battery is pretty much smooth dc at low inverter loads, with ac ripple increasing in amplitude with higher inverter loading.
The ac output voltage from the inverter is pretty much tied to the instantaneous dc bus voltage on the electrolytics and voltage regulation of the transformers.
A sudden transient surge on the ac side may well be catered for by stored energy in the electrolytics, in which case very little actual voltage correction by the feed forward system may be required.
The electrolytics slow down voltage changes across the dc bus, and give the feed forward additional time to correct.
Its common on commercial PWM inverters to have minimal sized electrolytics for cost reasons.
One of the main features of a home brew Warpverter is the massive (no cost spared!) bank of low ESR electrolytics.
That goes a very long way towards achieving very good step load change performance, both increasing and decreasing.
An ultracapacitor bank would be the ultimate if costly solution.
Just had a look at my Hall sensor, its an HSTS21 with +/- 100 amp range.
There are a whole family of these things, including a +/- 500 amp version and a +/-400 amp version.
https://www.ebay.com.au/itm/235319655247?itmmeta=01HVMTRCWV6BHQ1NYGYGMXFP46&hash=item36ca24fb4f:g:lJkAAOSwkP1d5iuw&itmprp=enc:AQAJAAAA4DZFDtc1Q2ir8IgrU/hWxXTWReC0pMDDM/jr56eJM/i6bgxsijQzaUBL1pKYfLXe61c/B9DPFA8Imto031U3iy5uPnbr6gMw3nWNZkXxPFevcj9l8xWflAGUvmEy9qXUEyVRVZiALFzKMKV4V5TVO2NtcWAbDp9rYcpR4+i+v78lgPzxKJouK/G3eBTWuGg26o+zygCqS5mM2twymx50tFpDR0iiZaSQUBt9UW6ulJ21TwxAfvNNs+yKI4p5nstlCUVN2ofdE1vOD4MdNJyEl5q5UuhZ5GP5X48vPVX8Mykb|tkp:Bk9SR8DO4ZrdYw
These use a +5v supply, and they have inbuilt potentiometers for adjusting the +2.5v zero output, and also the output span.
My previous explanation of it having a +/- 2v output span was not correct, its +/- 625mV which is more than enough.
There is also this one, which is the same kind of thing but requires +12v supply.
https://www.directindustry.com/prod/shenzhen-socan-technologies-co-ltd/product-132598-2600179.html
Thanks guys I've been enjoying the dialogue. Hopefully some of it sticks and I understand it better.
Here's the specs from the range I bought from. I've got two of the middle ones ... 300 amps. I planned to fit the other in the combined outputs from the four charge controllers.
It came from here ... https://www.aliexpress.com/item/1005001367453644.html?
It says (cut and pasted):
Ah so !
Haha, yeah I read that too. 😁
Those are the ones that KeepIS used on his inverter build and for his peak current meter. You can see some of his comments here ... https://www.thebackshed.com/forum/ViewTopic.php?TID=15417&P=21#205106
and another post here ... https://www.thebackshed.com/forum/ViewTopic.php?TID=15417&P=21#205172
Pretty sure Klaus used the same ones for his version of the peak meter. He sent me a pcb so I can build one too.
The ones I bought need a 12v supply and as far as I know the O/P varies between 0-4v ... with 4v being 300A in this case.
I just need to power mine up (it's already fitted) and monitor the output pin and compare with the clamp meter. Should have done that last night.
EDIT: On the link for the current sensor, look for any of the "View more" buttons hidden between the adverts and you'll be able to see all the details.
Those D-C2T sensors appear to have a zero to four volt output, although that is not exactly clear.
For the Warpverter feed forward current compensation to work, you need to have +2.5v output at zero current, then plus or minus current reading either side of the +2.5v zero.
If I remember, Klaus used an HSTS-400 amp sensor, and I used an HSTS-100 amp sensor which worked very well for me here.
For measuring surges and peak inrush, a digital CRO triggered on the rising edge is what I use.
Some of the better quality multimeters can sometimes have a peak hold function too.
Yes I think that's how they work though I need to hook one up to check for sure.
Ahh yes ... in all the excitement I had forgotten that key point ... and also that they need to read both ways to cover the backfeeding. Doh!
Are they HSTS21-400? I found a datasheet for them ... and they look the same profile as my existing one, so should be easy enough to swap over.
Yeah I can use mine but I get a bit lazy dragging it around to the inverter and then 5 mins later needing it on the bench, though I do have a peak hold function on the clamp meter. I'm pretty sure that eventually I won't look at any of that stuff ... but while I'm learning how everything works some actual figures and levels have been very useful.
You are quite right, just went out to the shed and had another look.
The one I have here is an HSTS21-100. That is plenty for me, my full load current is only 50 amps.
There are a whole family of these including 400 amp and 500 amp.
https://html.alldatasheet.com/html-pdf/1154780/YHDC/HSTS21-400A/115/1/HSTS21-400A.html
Isn't the DC bus voltage already one part of feedforward? DC bus current is just additional feedforward to compensate for I*R losses in transformers/wiring?
As far as I can see both options have their positives and negatives:
DC bus load current compensation: slower to react, compensates transformer/wiring losses only partially in transients (can't compensate voltage loss on transformer resistance if it doesn't show in DC bus current due to huge DC bus capacitance!)
AC load current or DC current between bus and H-bridge compensation: faster information about load current but more noisy, possibly need to be filtered heavily so that ends up as slow as the DC bus measurement.
Yup, you have this pretty well all figured out.
Feedforward attempts to compensate for conduction losses and the resulting voltage droop within the inverter and inverter wiring.
Its not perfect, but it has much better overall dynamics than voltage feedback for sudden large step load changes.
Its certainly faster, and might be potentially more prone to noise.
The noise problem can be largely overcome by using a dual slope integrating analog to digital converter that is synchronized to the inverter operating frequency. The integrating function largely removes impulse and high frequency noise.
Having a large low ESR capacitor bank also goes a long way to improving dynamic response to sudden load changes from the large stored energy, and that too helps remove noise from the incoming dc.
The final result of using feed forward, trades off some static voltage regulation accuracy for speed of response to sudden load changes.
The grid voltage goes up and down by a few volts during day and night, and everything still works just fine.
What is far more objectionable is light flicker when something like a large induction motor starts up (refrigerator).
Voltage feedback slowly ramps and corrects, but it still a comparatively slow process, which can become unstable if it over corrects.
Feedforward is faster, and unconditionally stable, but output voltage consistency is less than perfect.
Ac voltage that slowly wanders up and down by a couple of volts, is never a real problem.
Sudden voltage surges and dips that cause light flicker is far more objectionable.
The wandering voltage issue could be fixed by using very slow feedback in addition to the much faster feed forward.
Its just that the added complexity would be difficult to justify.
You could at least in theory also do the feedforward to reference voltage from the AC output current. Analog domain only, no need to get the AD-converters in the mess.
But I also envision it as more unstable or prone to oscillations, especially if you over-compensate with the feedforward.
If you use the output for control, then it becomes by definition feedback !
Getting a fast precise measurement of ac is always tricky, because it never stays still, always swinging up and down, and as you say, a PID control feedback loop can very easily over correct and become unstable.
If you overcompense with feedforward, all that happens is that voltage droop turns into a voltage rise with increasing load.
The inverter then has a negative output impedance. I wondered if that could ever become unstable, but it turns out that it does not.
The inverter load will always be (mostly) resistive, and that swamps out any slight negative output impedance of the inverter.
If you go absolutely crazy with feedforward, I am sure you could provoke oscillation, but with a practical inverter I have never seen any tendency towards instability with the current correction tweaked right up.
Its all been a quite fascinating thing to play around with.
I'm not sure about terminology and this goes to maybe irrelevant nit-picking for this thread.
But I would still call it feedforward as output current is not really the end goal (output voltage control is the "end goal")
It is still open-loop "best guess" of the needed compensation unlike feedback.
Also it doesn't have any error amplifier-part that I'd imagine as a part of feedback control.
(You could have also feedback from output current if you had sinusoidal reference current that you could feed to the error amplifier but then your inverter would have current output)
The whole concept of feedforward is that all the inputs drive some algorithm or lookup table to produce as you say a "best guess" at providing the desired result at the output.
The advantage is to provide a theoretically instantaneous correction of multiple rapidly changing input conditions, sacrificing some accuracy of output for a huge improvement in overall reaction time.
That was my purpose, faster response to large step changes in inverter load.
Its also much easier to detect and measure sudden changes in dc rather than ac.
Measuring the water depth of a still lake, is a lot simpler than measuring the precise average water depth with a strong ocean swell running.
Hi, there haven’t been any comments here lately so I thought I’d update some details on my Warpverter installation.
I mentioned a while ago that on good solar production days I was running 6kW of underfloor heating for hours every day
After a only a few days of this I realised that it really was feasible to run the underfloor heating on our solar … at least during the good weather until the grey days of winter … so it occurred to me that more panels and an extra inverter might be worth investigating. Almost immediately I found 6.6kW of Jinko panels and rails, with a 5kW Growatt inverter for sale on Marketplace for $1,000 AUD … and only a couple of years old. Only catch was that I had to remove them myself.
Another catch was that they were 440w panels … so bigger than the usual … but only 15 of them. Fortunately my brother in law was visiting, so he and my wife came along to help. Just as well too coz those panels are heavy.
As soon as I got home I levelled the ground along the north facing wall of the shed, leaned all the panels against it … and hooked them up. I ran a rail all the way through to bind them together and clamped all of the bottoms together as well … then used steel cable to anchor them to the shed so they couldn’t blow away.
Hooked them up in a string of 7 and one of 8 and fed them through to the inverter inside next to the Warpverter. Hooked the Growatt up to the output of the Warpverter (which acts as my grid) … then turned on the DC.
After 60 secs of thinking and syncing … it started to feed through power … just building very slowly until it was supplying about 2.5kW … and the Warpverter output was reducing at the same rate. The normally quiet hum got quite a bit louder, which is the same as when the wife's electric blanket is on ... but hasn't seemed to have any ill effect ... and slowly fades away again when the Growatt finally runs out of solar power. The noise hangs on even if there is only one watt of power.
So of course, ever since I’ve been flogging it like crazy … and while the sun is good, the Growatt provides 5kW for hours each day and the Warpverter provides the rest. Again regularly up to another 6 or 7kW.
We put a 2,300w oil filled heater in MIL’s room on a timer and another 1,000w one to move around the house … so regularly running 9.3kW of heating for up to 7 hours a day … and the smaller ones until later at night.
Before I started the underfloor heating, the tiles were 17-18C … but after a week of running them, the highest I’ve seen them has been 31.5C. A bit extreme of course, but it holds the heat well and really does keep the home cozy. Ideally I’d run them much lower but for many more hours … but I’ll take it when I can get it.
At present, management is purely manual … and I have to keep an eye on charge rates and battery level and simply turn on or off the various heating loads to keep it smooth. This morning I wasn’t paying much attention and only checked about 10.30am … and the battery was charging at 207amps. I did see it up at about 216 but the phone rang as I was trying to take a shot and I missed it.
Of course the heaters all went back on again to take advantage of the “free” heating energy.
So … all that to say that a Warpverter seems to be comfortable to be used in an ac-coupling situation … and if I were to ever see another bargain like the last one, I reckon I’d be keen to add it as well.
The highest outputs so far were a day where the Growatt generated 37.7kWh and the Warpverter just over 40kWh ... and many others have been close to that. And we used to use an average of 20-22kWh. 😁
I still need to tidy up the wiring to the Growatt ... and the rack sitting on top of the Warpverter is an additional dozen 47,000uF 63V capacitors hooked up in parallel with the original 6 ... for a total of 846,000uF !!!
Is the Growatt AC coupled to Warpverter?
Were loads in excess of what Growatt put out, so Warpverter simply reduced its own output?
Or have you implemented frequency shift to regulate Growatt output?
Or, although Growatt exceeds loads, it simply backfed through Warpverter charging batteries (which didn't reach full)?
Ordinarily, Warpverter is just an inverter. Should also work as battery charger. I've thought separate monitoring of battery voltage could be used to alter frequency. Also enable dump loads.
Would have to design some form of VCO for clock oscillator to get that frequency shifting.
Or DDS. Or just a digital value fed into a counter.
Not making a sine wave, just a clock with variable timing to step through the ROM which does make the sine wave.
But analog control loop to analog oscillator is appealing.
