Hoping someone's already done the hard work
ive just received 8 304ah cells and a jk BMS (200a cont 350 peak)
what 24v inverter should i buy? 4.8kw is 200a is it as simple as that? does any one have recommendations?
HEYVictron 24/3000 is a good choice? Unless you want an all in one
Basically looking at the 3000VA and 5000VA in the 120V range for 24V models.HEY
nope purely just an inverter.
i was hoping for more than 3kw and i believe victrons next one ups 5kw which is to much.
HeyBasically looking at the 3000VA and 5000VA in the 120V range for 24V models.
That's 2400, 4000 Watts assuming 1.2x power factor.
It's to do with reactive versus resistive loads.Hey
i need 240v out as im uk.
i dont understand the bottom line
cheers
thank you that makes sense now, what inverter would you pair with my battery? as large as possible,It's to do with reactive versus resistive loads.
I'm not sure what UK pricing is but in the US the 24V multiplus 2 3k is around $1100, I don't there is a multiplus 2 24V 5k so a big step up to the 24V Quattro 5k at around $2800. You could parallel two of the mp2 3k and still be below a quattros price.thank you that makes sense now, what inverter would you pair with my battery? as large as possible,
Hey,A larger inverter will not draw more power unless additional loads are added. I would recommend a rating of at least 20% higher than the anticipated load. Even more if the power factor is bad.... may need 40%-50% extra. Not that the load draws more power but more apparent power may be needed to power the item.
Depending on run time a second battery could be needed.
