I already knew the answer to the question I asked, hence the
You are using the BMS communication for charging control, that doesn't apply to anyone charging LFP with a USER setting in the charger. Huge difference.
Now if you quit using BMS communication, will you use 58.8V?
It's a rhetorical question of course.
Perhaps, but to the point, of course not, because
that is not the specification provided by the manufacturer of my batteries. EG4 spec is 56.2 for the Bulk charge +-0.2v and 54v float charge +-0.2v so if I was so inclined to not use BMS communication, I would make sure any manual setting is in that range. The Ruixu specs 56/54.6, so I would set the 2nd one to those values. In other words I would probably RTFM and use numbers they told me, unless had a compelling reason not to.
The whole charge portion of thread was started because of a suggestion that maybe the bulk charging level was set too low, which apparently it is not, since the vendor had suggested 58.0 (58.8 was listed as the maximum, 58.0 was listed as the end of the bulk charge range). Someone suggested that will blow up the battery, I merely looked up the manufacturers data sheet for the batteries, and noted that the numbers he was told to use fell within that spec.
Now the vendor could be totally wrong and clueless about the product they engineered, so far be it for me to dispute anyone here who has done actual research with the exact same cells and hardware that is in the Big Battery units. OTOH I did not see anyone with Big Battery batteries, commenting so I would weight any comments accordingly. A lot of the folks here have done a lot of work with a variety of BMS's and cells, so they have formed their opinions based on that research, I would never intimate they should be ignored, I'm simply noting what the manufacturer says.
Frankly I think it's crazy not to make sure all your stuff speaks the same language before you buy it. Based on responses to my earlier queries it shouldn't matter how hot you try to charge it the BMS will stop it. I'll stick with BMS comm, but I'd also lean towords what the guys who engineered it say, though that could indeed be sub-optimal. I notice with the BMS comm the voltage actually drops well below the listed 54v float voltages at 100% charge, and EG4 extends the warranty with EG4-EG4, so I'm guessing they are looking out for their own interests with the magic charge rates I see. No pony in this one, just noting what the builder sez
