Here is what the 1 of 20 senseboard looks like, front & back.
A couple components of the EMS (energy management system) of Elite GBS batteries which comes as a package.
*CPU: Central hub of the system, powered by 12 volts DC, controls alarm output signals, measures current, calculates state of charge, outputs video signal, detects ground fault conditions.
*Four cell sense board string x5 daisy chained, simple easy installation connected to the prismatic cells, measures voltage and temperature of each cell, performs cell balancing.
On the display screen there's the cell voltage/ temp screen or switch to the battery pack voltage, charge/ discharging current, SOC.
GBS uses a per cell sense boards for voltage and temperature, top balancing per cell shunts, a system shunt for current monitoring and coulomb counting (BMS) and 2 high current protective relays.
**Over voltage (highest cell is over 3.8V after a 3 second delay)
** Under voltage (lowest cell is below 2.8V after a 30 second delay)
** Over current (current exceeds 10C for 10 seconds)
**Over temperature (highest cell exceeds 150°F or 65°C)
**Under temperature (lowest cell is below 32°F or 0°C, charging is not allowed)
**Ground fault (There is a high voltage leakage greater than 2mA to the chassis pin)
**Unmanaged cells (The programmed number of cells does not equal the number of cells read)
