Roswell Bob
I am familiar with circuits that switch resistors in and out to balance cells. I am curious to know of any balancers exist where a mosfet is used in the active region. A mosfet can dissipate as much power as a similar size resistor and the power can be varied as necessary to balance the pack. A simple op-amp can be used to control the gate voltage so as to control drain current. A grade A battery would probably not benefit from such a device, but some of the lesser valued cells could be coaxed to work where otherwise they may best be scrapped.
So any active balancers being used?
