That really comes down to the load you will be placing on them and how you will be configuring them. Are you planning on parallel or series? What will your peak current draw be, or what will you be running off them?
With demands that low 10 gauge would be ample, you could certainly go lighter. You'll have charging of course so that may well be higher current than your load.
The AWG – American Wire Gauge – is used as a standard method denoting wire diameter, measuring the diameter of the conductor (the bare wire) with the insulation removed. AWG is sometime…
every question here is not a ridiculous question, this is the main purpose of this forum to help everybody, every day you learn new things including myself.
