Yes series increase the voltage which would decrease the voltage drop as a percentage.1200 watt solar panels, 12 volt, wired parallel need to run 100 feet to batteries. What would be the wire size and would it benefit me to wire in series?
Thanks
We need to see the keys and the values.300 watts, 18 volts, 3.12 amps 4 panels for 1200 watts total
Depends on your solar charge controller but if your solar charge controller can handle 72 volts then go with 72 volts.When I can get on the roof I'll get the info off the back of the panels. Sorry I don't have it with me
However, which is better for charging a battery bank 72 volts and 6 amps or 24 amps and 18 volts?
You need both.Thanks
Huge help
But which is better for charging a battery bank if distance is not an issue, Amps or Volts?
You're welcome.Thanks for clarifying that for me
The MPPT controller will convert to 14 volts and the rest in amps. Watts to the battery will be the same.When I can get on the roof I'll get the info off the back of the panels. Sorry I don't have it with me
You have not given us any information on your solar charge controller.
What do you suggest?If you are planning a 12v bank as stated, that SCC is way under powered for the amount of solar you have.
