Wattsinwattsout
If you own a WZRELB Reliable inverter you should do a quick safety test for continuity between the terminal bus hot and the case outlet hot connections. If these are not wired correctly you can have a cross feed of power to the neutral terminal bus and if that is connected to earth ground it can blow the unit. If untreated it can damage equipment and or create a safety hazard.
If you own and use one of these inverters please take the time to check the factory wiring. The two I have tie the terminal hot to the outlet neutral together. The neutral outlet connection is back feeding current as soon as you plug something into the outlet.
I have made a few videos of this issue and how to fix it.
P.S. These are very well made inverters, they use very little idle current, they handle their rated output (as long as battery supply and cables are sufficient), and they last a very long time. I own two of them and may buy another split phase unit in the future. I think this is just a wiring diagram issue in the factory or a lack of QC oversight for this particular issue. I have reached out to them(WZRELB) twice but have not yet received any response.
