Xantrex C60 Max input PV Wattage
Wadzanai
Hi Everyone
Kindly assist. What is the maximum PV wattage input for Xantrex C60 PWM charge controller. The specification sheet only mentions max PV array open circuit voltage as 55VDC. I tried searching online but I can’t find anything.
Thanks
Regards
C60 is only good on 12/24V systems.
12V: 60A * 15V = 900W
24V: 60A * 30V = 1800W
As far as the maximum PV input current for over-paneling, keep it under 60A since this is a PWM controller, and it really can't be over-paneled.
Thanks Sunshine
A shop is selling them for a discount, they also have the C40. My inverter is 12V/220, my DC fridge is 12/24 so I thought it would be good to go for a C60 instead of a C40, the price difference is only equivalent US$15. Is a C40 better?
Regards
Wad
The C40 is a very useful controller for wind or hydro on 48V systems.
In your case, for 12V, the C60 is the better option due to the higher current.
While it says a limit of 55Voc, you still need to select "12V" panels with a Voc between 20 and 25V. This puts Vmp around 17-19V. They must be placed in parallel.
The total Isc of the array should be less than 60A.
If you select panels with higher voltage, you waste everything above battery voltage.
