hogback
I have an XW+ that I've been using off-grid for four years. Nothing wrong with it. I'm about to power the system down to swap to different batteries, and was perusing the operators' manual for refreshing my mind, and I saw this:
AC_Coupling AC Coupling function is enabled by default (Advanced Features Menu) and should remain enabled except in cases where the DC voltage level is allowed to have large variations and the AC line frequency needs to remain constant.
I'm assuming this term "AC Coupling" has nothing to do with and AC vs. DC coupled system (mine is DC coupled). I've read the description over and over and it is not registering for me. If this term has nothing to do with the common meaning of AC or DC coupling, is the just a poor choice of words on Schneider's part?
I also have an XW pro (two actually) that I've been playing with in the garage for a possible auxiliary or backup system. One of these seems fried (likely by me - it seemed fine when I first hooked it up - now all options are greyed out in insight local, so I can't even restore factory defaults. I had played around with SOC info from a BMS and might have set some things wonky. I had thought that I had set the AC Coupling option incorrectly). I do remember that there was a similar option for AC coupling in insight local for the XWpro, so I guess I'm asking what this setting is for and why you'd want to have it set one way or another, and what the ramifications would be with it set incorrectly one way or the other.....
Thanks in advance if anyone has any insight (pun).
