EEL box with JK BMS
G00SE
There’s two O’s in G00SE
NAZ
Just got an email showing a promotion for the EEL box with JK BMS
Not a bad price at all for $539
If I have 2 boxes already with the old BMS (which I believe is simply a seplos) would one have advantage to add 2 of the same, or would adding 2 with the JK BMS work fine?
Is there benefit to this over the seplos?
Which EEL box and who was offering the promo? Thanks!
Wow EEL have jacked their prices up and made the options more obscure. I would look elsewhere now if I was in the market for more boxes.
Different BMS can't communicate with each other I think, in Andy's YouTube, he posted JK BMS is good until now. By the way, 539usd for 1pcs EEL box include shipping? What's the model of JK BMS?
I just got a very interesting quote from EEL. The prices are almost too good to be true! Also, JK came out with a firmware update that addresses most of the issues Andy found! I think these from EEL are by far the cheapest on the market right now!
  • EEL INVOICE.pdf
If I did my math right that is about $0.13/wh, with some assembly required.
Do these boxes have a display? If so, I think these are the V4 boxes with Seplos BMS and JK active balancers. Eel boxes with JK BMS do not have a display.
$73.00/cell for the 280K Grade A sounds too good to be true, so I would make sure they commit to sending you a manufacturer test report because so far the only thing I have seen from EEL is a fake knock off EVE terminal.
NOT down playing EEL, I have there v3 kit, but claims from them being grade A seem to be un substantiated.
Hello - no display at this moment for the new JK-BMS V4 diy kit... :oops:
source :
Screenshot 2024-01-16 at 08-06-03 EEL BATTERY V4 DIY Kit Full Assembly Instruction.png
I just ordered four custom 8s boxes for $160.00 plus $110.00 for JK BMS with screen each. Not sure on the 48 volt boxes but I don’t think they are over $300.00. You do need to start a chat to get a real quote with shipping. Shipping not included in above price, I also ordered 36-304ah EVE cells and a few other things. Shipping was about $575.00 for everything.
Can you provide a link to the EEL box you purchased?
Also buying 12 of them, is that why you paid $397.00 each to include the new JK Inverter BMS 200Amp with Active Balancer?
Thanks
Scat
