S Davis Solar Enthusiast Joined Sep 25, 2021 Messages 657 Mar 2, 2024 #21 What was your final cost on the boxes with BMS and shipping?
nebulight Solar Enthusiast Joined May 14, 2020 Messages 206 Location Las Vegas Mar 2, 2024 #22 434 without the BMS.
S Davis Solar Enthusiast Joined Sep 25, 2021 Messages 657 Mar 3, 2024 #23 Ok I was just quoted $210.00 for the 48 volt box with 200amp breakers and wire before shipping.
nebulight Solar Enthusiast Joined May 14, 2020 Messages 206 Location Las Vegas Mar 3, 2024 #24 Shipping will kill you. I got the whole kit minus BMS.
S Davis Solar Enthusiast Joined Sep 25, 2021 Messages 657 Mar 3, 2024 #25 nebulight said: Shipping will kill you. I got the whole kit minus BMS. Click to expand... I got a 24volt box kit and 8 cells shipped for about 130.00.
Pierrot New Member Joined Apr 21, 2020 Messages 25 Mar 8, 2024 #26 hello, I'm not sure I like the JK BMS box "cables" as much as the Seplos box "bus bars" - what do you think ? V4 Seplos box vs V4 new JK-BMS box Last edited: Mar 11, 2024
B Beny New Member Joined Jan 21, 2023 Messages 1 Location Kladno Apr 13, 2024 #27 Pierrot said: hello, I'm not sure I like the JK BMS box "cables" as much as the Seplos box "bus bars" - what do you think ? V4 Seplos box vs V4 new JK-BMS box View attachment 200991 Click to expand... If you don't like the size of the cables you can make new, thicker ones. For me this is the attraction compared to Seplos.
houseofancients Solar Wizard Joined Nov 29, 2019 Messages 3,953 Location EU Apr 13, 2024 #28 Beny said: If you don't like the size of the cables you can make new, thicker ones. For me this is the attraction compared to Seplos. Click to expand... Why is that ? You can easily use what ever size you want on the seplos , just order the proper futoronics connectors. The internal flex busbars are rated for 450a
Zack Lin New Member Joined Mar 21, 2023 Messages 30 Location Guangdong Apr 16, 2024 #29 Alkaline said: LF280K Oct.28th.pdf drive.google.com This is the test report they put up, looks very different from the one from batteryhookup: https://cdn.shopify.com/s/files/1/2398/3077/files/LF280K-1008-9_25_-3400pcs.xlsx?v=1700496327, missing a lot of fields, is this the first knock off test report? I'm going to send it to EVEbattery and see what they say. Click to expand... Indeed, since EVE starts their own retails business also, so for those sellers without official authorizations, EVE will print mark B on every cells.
