Combine 2x 8S 24v Systems
WillAK
I have 2x 8S 24v 280ah LifePO4 battery packs which I want to combine to create 1x 24v pack.
I have 2 separate BMS which are 24v 8S.
What's the best way to connect these together? I don't have a 16S BMS so should I run two separate BMS 8S and connect in parallel?
Also, would I need to top balance 16 cells and after, separate into 2P8S?
Thanks.
A 16S bms is for 48V. Two cells in parallel are a single cell.
Connect them in parallel as two separate 8S batteries each with their own BMS. Wait until they are about 0.2V apart before making the connection.
Top balancing is only needed if the individual 8S batteries are in need of top balance.
Yes of course you're right.
But what about if I put 2 cells in parallel and just use one BMS?
  1. You lose single cell monitoring.
  2. You cut your current to the limit of ONE BMS rather than most of the two.
  3. You lose redundancy - if one cell or BMS has a problem, you simply take that battery out of service and continue on the other. If you run 2P8S and there's a problem, the whole shebang is down while you troubleshoot which of the 2P cells are bad.
There is one good reason to parallel cells: when you have absolutely no other practical choice. I don't see that you're there.
What BMS do you have?
If you already have 2 BMS there’s no real reason to only use 1.
People have had success using 2P8S and one BMS but it is kind of frowned upon.
I personally had a 2p4s before converting it to a 8s, and I had no issues with it as a 12v system.
Granted it was for a very very low usage, maybe max current of 20-30a or so.
When I do add another 8S to my current pack I’ll be using another complete BMs build wired into bus bars.
I have 2x JK 200a BMS which ive been using for a while. I will just connect the 2 cells in parallel and continue.
Does anyone have a wiring diagram for 16S in 8S2P with 2x BMS?
Well that's me convinced. Thanks very much!
Huh? I hope you meant batteries?
Imagine you have two 12V batteries, and you want to parallel them. You simply connect (-) to (-) and (+) to (+). That's all you need to do here.
When you connect the parallel batteries to your system, you connect the system to the (-) of one battery and the (+) of the OTHER battery.
See link #6 in my sig, section 3. Several options on paralleling batteries.
Yes I do mean batteries.
I don't have a problem putting them in parallel I'm just wondering how I would wire up the two BMS. Which would then be the main negative if I have two of them?
I guess Ill just shunt them both together the pos and the neg's.
I don’t believe there will be an “main negative”, they will all be equal.
Each BMS will have its own negative off the BMS terminal, and each positive will be off the most positive cell terminal.
There will be no BMS interaction or wiring. You treat them as completely separate batteries connecting only at the (-) of each battery and at the (+) of each battery.
Please review link #6.
Im putting together the following and am concerned as to how to determine which BMS to use , which rating for the bus.
I am running 4-540 watt panels on the roof, each at 49.3 volts, all Victron equipment: 3000/24/70 inverter/charger; MPPT 250/85-Tr VE-Can; Brian 24-12 dc to dc converter; GX tank 140; Lynx count VE-Can; Lynx distributor 1000; 32-3.2 volt 280 ah cells configured into 4 - 8s batteries at 24 volts each.
My question is which BMS should I use one each. I like the JK but do not know how many amps each BMS should should be rated for.
do I install the BMS as normal and the run the four batteries in parallel? is there any secret as to them speaking to each other or just run main positive to MPPT and the main negative to the MPPT and the is all there is too it?
No higher than 280A and as low as you can tolerate.
3000W/25.6V/.85 = 138A max draw from your inverter
Thus a 150-200A BMS would more than handle all current your inverter could draw. You can also consider lower ratings since you're dividing the current across 4 batteries. Personally, I wouldn't go below 100A per battery.
You install a BMS on each 8S battery and treat them as four separate batteries. Then connect the batteries in parallel only at their main (+) and (-) terminals.
Click Spoiler in my signature and review link #6.
