Apologies for late reply. That would have been from the charge controller.
I've updated the system now so it's all changed.
Done.Some feel every wire/component should be fused.
I’d toss an ANL or Mega or MRBF on each battery.
Yes, I used a smart charger to ensure they were charged fully. I've updated my system now with Victron equipment and they stay charged for much longer.Hi, when you first connected the batteries in parallel, did you charge both batteries to full and check that they were at the same V with a max difference of 0.1V when the batteries were sitting in for 1 day before connecting them in parallel.
You said you didn't have a suitable charger, so I thought you had skipped this exact step to balance the batteries before connecting them in parallel.
Situation seems to have resolved itself now that I've changed to Victron equipment.I the the OP needs a 'battery equaliser' also sometimes called a balancer.
There's loads on eBay, something like this:
eBay Battery equaliser
Seems to have resolved itself now that I've changed to Victron equipment. Although we are obviously getting a bit more sun now.This could have damaged your batteries. Many solar charge controllers SCC are preset to lead acid batteries which is probably why it worked well for those when you had them. Best case scenario is your scc tried to bulk charge and equalize your LiFePo4 batteries and caused them to shut themselves off at some point instead of charging. Then when they woke back up you drained them and they never got charged to 100% ever again. Luckily since the BMS most likely did it’s job all you have to do is find the user defined settings for your SCC and turn off the equalizing mode and lock in the charging voltage at 14 volts or so. Then give them a few days to recharge.
I’d say you fixed it not “resolved itself” lol your Victron equipment is most likely set for Lithium charge parameters so you should be good! Glad it’s working!Seems to have resolved itself now that I've changed to Victron equipment. Although we are obviously getting a bit more sun now.
You can run multiple chargers too if you need more power than what it puts out.
I don’t argue with them it’s decent enough gear. Just poke fun at their cult like devotionWasn't me it was from someone else arguing with the victron cult members
I wouldn't mind buying the blue stuff, but I would have to get another job to afford itI don’t argue with them it’s decent enough gear. Just poke fun at their cult like devotion
