Totally agree - got mine from @HighTechLab and they were packaged the same way.
No, you can run them independently.if you have a mix of EG4 and RUIXU battery banks, is there a setting that will read both on the 6000xp?
The manual is quite thorough, 28 pages with tables, and illustrations. It puts the EG-4 stuff to shame, very professional looking with little if any Chinglish, easy to understand.Is everyone still happy with the Riuxu batteries? I'm considering the 10-battery rack to pair with a Sol-ark 15K.
Any issues getting comms working properly?
The SOC may deviate if you ever have a load of less than 0.5A per battery.. Any time less than that will not be recorded as consumption by the BMS. So if you left the inverter on idle for a week, without solar input, the batteries would die with 99% SOC indicated.My batteries are performing quite well with 2 X 6000XP’s. Communication works and seems to measure voltage well.
The Ruixu rack is really nice.
My one issue is that I’ve seen my SOC% deviate from my voltage somewhat, but haven’t drilled into it to figure it out completely. Also, they are not on 6000XP’s battery compatibility list, so I wouldn’t expect the communication to work flawlessly.
I think that is exactly what happened. Phase 1 (complete) of my project was putting in a battery backup system. Phase 2 (next 60 days) is adding the Solar. In wanting to keep my batteries fully charged in case of a power outage, I put the inverters in bypass mode, so I was drawing nothing from the batteries. It took almost 2 weeks, but suddenly the batteries started charging due to voltage. Didn’t understand why.The SOC may deviate if you ever have a load of less than 0.5A per battery.
You will like Ruixu battery.Is everyone still happy with the Riuxu batteries? I'm considering the 10-battery rack to pair with a Sol-ark 15K.
You are aware that good hf inverters carry a 10 year warranty ?Does anyone know if a transformer based inverter like a Sigineer low frequency would pair well with the Ruixu rack batteries? Yes, I know I wouldn't have communication and the warranty voided but I cannot bring myself to purchase one of those "all in one" HF units that probably won't last 7 to 10 years...and besides I want my off grid to run whatever I throw at it. And lets face it, the components in those "all in one" units just aren't heavy duty enough and will wear out faster than a transformer based inverter.
Maybe I need to call Sigineer or Ruixu for the answer but if anyone here knows, then thanks.
Yep I am aware.You are aware that good hf inverters carry a 10 year warranty ?
Also, if you properly size a hf inverter, you won't be having any issues
A battery is a battery to an inverterYep I am aware.
"properly size" see that is part of the problem. That really means:
1) "oversize" for what you will need to run.....which you shouldn't have to do in the first place
2) And still the components inside the HF inverter/charger will be inferior to a transformer based system that can easily run inductive loads and surges....and those components in the HF inverter/charger will indeed wear out much quicker as you have a more complicated cycle that needs to be completed (with more electronic components) to replicate the transformer inverter/chargers
This has been discussed on this form before.....but back to my question (if anyone can shed light)
on Friday, May 3, 2024 4:02 PMYep I am aware.
