iwasforcedtopickausername
- Oct 13, 2022
- 48
I am absolutely perplexed.
2x 250W Santan solar panels in series feeding a PWM Tristar TS-45 (with screen module), which in turn feeds a SOK 48V 100AH server rack battery.
This setup was working really well, until some weeks/months ago, when I saw a high voltage disconnect on the Tristar. With a VOC of 36V per panel, I don't see how I could be hitting that, especially with the battery not nearly fully charged.
After that first high voltage disconnect, I started getting FET faults. I called Morningstar, got a very nice voicemail response, tried playing phone tag once, and just haven't found the time to call them back yet.
Here's where I'm really confused. I bought the TS-45 used and on rare occasion the FETs go out. I've found maybe two people on the internet claiming to have this happen. I assume it does happen, just rarely. So maybe I had bad luck?
Anyway, thinking about how PWM works, at least about how I think it works, it just shorts the panels to the battery and only goes into PWM mode when high voltage is reached. (Am I wrong about this?)
So, I wired the panels straight to the battery last night.
This morning, lots of direct sun. I check with the clamp meter and I'm getting no current out of the solar panels. If I turn off the breaker, I see a higher voltage than when I turn it on. My 10 amp fuse is happy.
Could something in the panel be bad, or am I being dumb?
I'd appreciate any help. Thank you.
