I recently got all my parts for the “Classic 400 watt” system Will recommended on his website and ran into a problem yesterday when I went to install the panels on the roof and wire them together. With the combination array of series and parallel, or in group series, you need to connect the 1st and 3rd panel and the 2th with the 4th. However, with the Renogy Z brackets for mounting on the roof the panels have to be 2-3 inches apart and the cables on the 1st/3rd & 2nd/4th do no reach.... they’re only a couple inches short, but don’t quite make it. I thought about staggering the panels so the brackets wouldn’t be lined up and you could get the panels closer, but then I can’t get at the bracket screws for mounting or sealing. So, my question, has anyone had this problem with the Renogy panels? I don’t know if they shortened the cables since Will made his videos or if that’s the way they’ve always been. Has anyone bought additional mc4 extension cables just for those few inches or just scrapped it and went with a full series or parallel configuration? Thanks a ton for any suggestions!
