Happy last day of the weekend!
Question- or two.
I read somewhere on the forums that the 18KPV PV1 inputs are in parallel and capable of 25A max combined input.
The manual agrees with the 25A but says nothing about the configuration internally. It makes sense that they are parallel.
With that said - couldn't you just make the parallel connection at the array and save the second wire pull provided the proper wiring was used?
Other than having the ability to run a smaller wire size and smaller currents to each input, I'm not seeing why the need for two inputs on PV1.
I'm curious.
Has anyone heard updates as to when the updated software is going to be released? "Soon" feels like awhile ago or am I impatient............
At some point I'd like to use the grid to assist if needed without back feeding. I get the impression from my reading here that the beta is working to prevent this along with some other tweaks. Personally I've been very pleased with the performance of my system so far.
Question- or two.
I'm curious.
