I just pulled the trigger on the 18kpv, 30kW battery and 12 460W bifacial panels. I am going to add them to the top of my pergola in the backyard (no shade at all). The panels will be about 35 ft from the inverter. I was planning on running a single set of 10gauge wires in metal conduit to the disconnect. I was planning hooking the panels up in a 6s2p configuration with 2 runs of 6 panels each in series.
Will this be ok to run off the #1MPPT on the 18kpv?
What Voltages / amps should I expect?
Thanks for your help!
-Troy
-Troy
