Given the cost of wiring these days, can I run 2 strings of panel over one 10/3 wire? Kind of like you do on 240 split leg.
So I'd tie the negatives from each string to one wire (like the neutral) and then one string's positive to hot-red, and the other string's positve to hot-black.
Would that work? Am I then limited to 15 amps (since two are shareing the negative) instead of 30 amps?
Thanks
Thanks
