Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 21,204
Also, there is some question of DC power introduced to the AutoTransformer that might damage it (apparently it's not the voltage, but the DC power on an AC line that messes with transformers). Transformers seem to be particularly vulnerable to these events and most off-grid folks don't have transformers. But we have several so it might affect us more.
Transformers have two or more inductor windings, coupled by a core.
At nominal operating voltage and line frequency, a 100A 240V 25kVA transformer might carry a couple amps (2% of rating). The current is 90 degrees later than voltage, so the energy it absorbs one phase is returned to the grid next phase, minus I^2R losses.
With current able to flow in the secondary, magnetic field is canceled and current goes higher, e.g. 100A at full load.
With no load, the core gets turned into a permanent magnet, with poles reversing every phase. That's magnetic domains of atoms reversing each phase (resisting change in field and current flow), and partially "saturating", running low on more domains to reverse. If you double AC voltage or cut frequency in half, it will saturate and current will shoot up to whatever resistance limits it to, about 35x rated current.
If you apply DC voltage to the winding, it resists current briefly. About 10 milliseconds or so at 240V, about 1 second at 2.4V. Then transformer core saturates, it stops resisting AC voltage, and current from AC power supply shoots up 35x, burning out the transformer.
The damage to transformer is cause by power coming from power plant. The DC current from CME, EMP, or a solar panel connected to one winding causes the inductor to stop working, so current is no longer limited. (Transformers can be used as amplifiers this way.)
The utility wouldn't like it if your transformerless inverter failed and PV string backfed DC.
