shadowmaker
I have 2x Deye 12K and about 100kWh of batteries. Up here in Finland my batteries are most of the time empty at this time of year so no backup for blackouts (which are thankfully quite rare). Generator sweet spot should be around 75-80%, so this one should be used close to 35kW, but I can only charge my batts around 21-22kW. It would be quite easy for me to add ~15kW more loads when using a generator (3x water heaters, pool heater, geothermal heating, 3x heat pumps...), but is there a bypass when using gen port? I mean can a generator be used only for charging my batts, or can it also be used to cover my loads at the same time? If so, how big is the bypass?
