Not sure if anyone actually seen 8000 real world cycles?
I believe the manufacturers have tested using higher C rates for discharge and charging. In a PV system, many member report having over 8 years on LFP with no degradation in capacity.
Yea over the long term you're right. But it's not as bigger difference as people might have you believe .
I already gave you the math, you're in some type of denial stage at this point. The difference is quite large.
Your figure:
"£1,350 ÷ 18,144kwh = £0.0744 GBP per lifetime kWh ($0.094 USD)"
My figure:
"For usable capacity of 48.6Kwh = $0.0377 per Kwh"
That is over 250% higher over the lifetime which is what wanted for a baseline. That is huge.
If a local bank told you they will give you a 250% return on your money over the next 25 years, would you take it?
If you don't understand how money works and how to make it work for you even while you sleep, then buy the lead acid. Easiest money I've ever made was while I was sleeping after putting my money in the right place.
no one is trying to make out lead acid is better than lithium, What I'm saying is there's plenty of people who can't afford to put the big investment in and still need the battery capacity.
I was being nice in prior responses but as you want to be argumentative, I guess I'll play along.
This comment:
"So I understand about all the disadvantages of lead acid, but I think that figure is going to be hard to beat ...."
is either you're trolling or ignorant as I quite easily showed you the figures and even used your cycle lifespan of 3500 and it still beat your lead acid or gel (don't care which) and it would run my house for 38 years if calendar aging didn't play into the equation.
If your budget is short, lead acid is a very attractive and viable option
I already gave cheap alternatives, you just choose to gloss over. Either trolling or not paying attention. First, the cheapest I found the GF06240V SONNENSCHEIN is
https://www.battery-direct.com/12v-240ah-battery-gf6240v.html which is 485Euro - $528USD - 415.50 pound sterling
Even though you used sterling, it still doesn't add up that you purchased 16 of these batteries for £1,350 gbp
Even with a quantity discount the price is "from 16 pieces 3% discount = 395.37 EUR"
That is $430USD. That would be $6880 USD plus shipping. 8 of these batteries make 48V battery and 11,520Wh. My bank is almost 5 times that size for less than what those 16 gel batteries would cost.
Who knows when the next advancement in battery technology might be, or how cheap lithium will be when these gel batteries are worm out in a good couple of years
The revolution wen right past you with LFP, I doubt you will catch the next generation.
