@Steve_S I'm not aware of any extra features for the BMS. No instructions of any kind were included. I'm guessing it would be a basic BMS for this price-point.
So far, I think the new battery is working well. Initial capacity test - Started with the 26.73V when I took it outta the box (not fully charged), I ran it down to about 24V (3.0V per cell), took all day. Got about 8.5kWh via a Kill-A-Watt meter (added 15% for losses). Had some issues with popping breakers on power strips and overwhelming the inverter that interfered with getting a good begin-to-end measurement (the meter would zero out). But, I feel comfortable these are 24V at 400Ah.
The two 24V 15A chargers (each are 27V 13A), one of them is not working. I opened it up and saw the fuse was blown. I tried to replace it with an automotive 8A 32V fuse but it immediately blew. I just received a pack of GFE 8A 240V fuses today, ordered from Amazon last night (8A 240V was listed on the circuit board next to the fuse holder). These are apparently hard to find locally. Hopefully that's all it is. If not, I'll contact the seller Shunbin.
I used the working charger over-night. Takes forever to charge the battery, averaging about 320 Watts per hour (~12A). Also, I charged the battery with my 1kW solar panel array during the day, which was averaging about 18A on a cloudy day (briefly peaked at 38A or 1,000 Watts). Between the 2, they charged up the battery to just over 10 Kw. One challenge I'm having is, I have various displays and meters and all are not consistent with each other, so this is a rough estimate (I don't have enough solar to charge 10kW in a day). I used a Watts-Up meter with the wall charger to get its numbers and solar charge controller MT50 display for its numbers. I think this was a well enough first test to give me a sense I didn't get smaller cells or if they weren't somehow to spec. They seem to be what they should be.
The BMS has been balancing as expected, both discharge and charge. I'd periodically check the voltage of each cell. All cells stayed reasonably close to each other in voltage throughout the cycle. The low-voltage cut-off is managed by a Victron 220A Battery Protect set at 23.6V, so I didn't get to see if the BMS would disconnect at low voltage. Though, the BMS did stop all charging when the battery was full, ~29.2V. I'd see green flashing lights on the BMS itself and both the wall charger and solar charge controller stopped pushing power. Highest cell voltage I saw was 3.63V. So, the BMS looks to be functioning as expected.
No temperature hotspots that I noticed (by touch and digital infrared thermometer gun), all cells were a couple degrees above room temperature. Ranged from 400 to 1,000 Watts per hour (low C rate) when discharging.
I have a coulomb meter, but need to hook it up with the shunt. I'll do a better test the next time around now that I'm starting with a full battery, but it will take me a few days to run it down again.
Overall I'm happy with the battery thus far. Only real issue is one of the chargers isn't working. Hopefully I just blew the fuse when I was connecting it.
