AC Breaker Size SRNE HF4850U80-H
e trouble
Alberta
15 amp breaker in my house panel keeps tripping if I leave parameter 7 set on default of 60 amps. I have tried lowering it but still trips over 15 amps.Explained to
SRNE technical support that I wanted at least 40 amp charge and was told I would need to use a 40 amp breaker.
If this is correct how does my 12 volt lithium charger charge my 12 volt battery 40 amps through a 15 amp breaker?
