Hi. I installed my own small grid tied system myself on the garage roof 15 years ago. I want to add a small battery backup to utilize the solar panel power generated when grid down in order to run a few critical circuits when the power is out.
Current array is twelve 220watt 24v panels in series sending 330ish volts to a dsquare disconnet, then to the Sunny Boy GTI to a 100a subpanel in the garage to our main 200a house panel.
I think I want to add a DC transfer switch just after the dsquare mechanical DC disconnect so that when power goes out I can redirect the 330v array to an all-in-one inverter/small battery bank. Don't know if I'd go auto or manual transfer switch.
What products are available to make this all happen? What's available on the market for a transfer switch that can handle 400volts DC?
I also have ten 100w 12v panels that have not been utilized in a number of years and I think I want to mount them to keep the battery bank topped off and run the few things I run in the garage where all this will be mounted.
I was thinking a EG4 3000EHV-48 since it can handle 500v and 1 or 2 of the EG4 Lifepower4 48v 100ah server rack batteries to keep it budget friendly, but not sure yet.
All input welcome and appreciated.
Chris
Chris
