Vigo
Solar Addict
I just realized my SCC won't allow more than 5A on the load terms. that's dumb! I'd nearly have to let it power a relay to disconnect the inverter. Silliness.
Not necessarily. If you simply wire the on/off switch of the inverter to the load ports of the SCC, it should work. That switch circuit is going to be nowhere near 5a. Does require you to lightly modify the inverter, but it's a pretty simple thing that needs doing.
