Is there a 200a 230VAC automatic isolation switch that can be used in US? An automatic transfer switch, especially for generators, seems over-engineered for this purpose when all that is needed is magnetic relay type of switch that will cut off the grid supply during power outage (by being positioned between the utility meter and first tap of the supply lines).
Investigating this in case local code or utility might require automatic disconnect from the grid even when the ac coupled inverter is anti-islanding certified.
I looked around this forum but didn't find anything that is big enough (200a 230VAC).
