jvbutter01
- Aug 20, 2020
- 208
according to my BMS after sitting on charger for almost 2 weeks now, i continue to have #4 cell (on pos output of battery) at 3.5v. The #1,2,3 cells are 3.33 , 3.33, 3.35. The Victron Energy BMV-712 Smart Battery Monitor, shows it NOT charging. I assume this is due to bms shut off from cell 4 at 3.56v. BMS setting is
Overvoltage 3.65v
Over voltage release 3.55
Pack over voltage 14.6v
Pack over voltage release 14.2v
I do have small scale power tester. Same unit WillP uses..
I used this 1x to drain down the battery voltage in that cell to 3.3 as the others, hooked back up is series config battery, and put back on charger. I know the battery charger PD9145AL will give a boost charge to 14.4v every 15min / 21hr cycle.
I feel there is some capacity potential there left on the table. I will use this in my RV and would like to use all the capacity i can for this type charger.
What are my options for getting this single cell down enough to get all 4 batteries to charge up to 3.5 max? Do I need to tear down the battery into parallel cells again, set them back on the smaller 12v/10a charger?
Overvoltage 3.65v
8 In 1 150w 180w Digital Battery Capacity Tester Voltmeter Adjustable Constant Current Electronic Load Charger Meter Indicator - Buy Digital Battery Capacity Tester,Usb Meter Indicator,External Battery Charger Product on Alibaba.com
www.alibaba.com
