Aridom82
Learning addict
So i am discovering how essential is to have very good contact between the busbars and the battery.
The problem is that the battery terminal does not have a flat surface for the busbar to rest on. It has like a raised outer edge and when you torque the busbar in it just 'bites' a circle in it. See picture.
So how do you guys deal with this?
I was thinking in filing a little bit the outer edge and then putting a thin copper washer with some battery grease.
I am not sure that it will get it to work to the 160 amp target though.
